KEP server and RSViewME
darrenj
Feb 2005
Ottawa
1,003
O.K. people update time!!
I have been trying to get a panelview plus to communicate with a Modicon PLC. All is well so far. i figured out the Kep server software and can control the PLC that i am connected to..(I connect to the PLC over ethernet). Now i am trying to bridge across the ethernet and control other devices over the Modbus Plus. Does anyone have any idea how i should go about this.. I read in the Kepserver documentation that i should add another device and add an extra octet at the end of the ip address. The octet would be the Node number of the PLC on Modbus plus.. Am i reading this right? My PLC IP addy is 192.162.10.100 the PLC i am trying to talk to on Modbus Plus has the addy 10..so would i enter the new device address as 192.162.10.100.10??
Any help would be appreciated..
D
If you are talking about using the MODBUS Ethernet driver in Kepware and you want to specify a node off of the bridge and it's address is 10, then yes that is what you would put in the Device ID field in Kepware.
Hello All, I'm trying to use a panel view to communicate to a siemens 505 processor and i have read that it has to be done using a kepware server...
2,318
Hey guys, I am entrusted with the job of reviving an old data logging system which has been dysfunctional for a few years.I have...
2,172
I need help to write KEP SERVER tags in Softlogix5800 or ControlLogix PLC(RSLogix5000) Actually In KEP Server I am reading GE Fanuc PLC...
2,028
Hi, I need to connect the KEP server as OPC (Version 4.264) to Micrologix controller. I'm procuring rslinx professinal to talk to opc as the...
7,156
Hello all, just a cheap old cheat note. I ran into the same problem most of us have seen, that field device talks Modbus RTU and I need more data...
4,717
