Keyance IV2 Cameras with Allen Bradley
patelaksh30
Mar 2018
USA
Hi There,
I am trying to setup Keyance IV2 cameras with AB PLC and out of 4 cameras, 3 of them have error "16#0114 Electronic Keying mismatch: Electronic keying product cold and/or vendor ID mismatch." and 1 camera is in running fine.
All connection parameters are same in generic Ethernet module and all cameras are setup identically same.
Not sure why it's happening but your help would be very much appreciated.
Thank You
Generic Ethernet Module objects, of course, aren't supposed to support electronic keying at all.
You are probably seeing a bug that's related to changing the Module Definition after creating the module. Somehow the internal flags for electronic keying get set =1 instead of being left =0.
I might have been the first person to discover this bug, about 7 years ago, and by coincidence on a Keyence IV-series camera sensor.
My recollection is that the easy solution is to save the project as a *.L5K and re-open it to create an *.ACD. The electronic keying flags should get reset when the module object is re-created.
HI, I need a tag file for the following scanners if someone has got it; SR 752 SR 1000 SR 2000 I would like to add a scanner using Ethernet...
1,836
I have a friend who is trying to read some info from AB PLCs inside a Keyance PLC. Trying to setup explicit messages, one needs a class, instance...
1,284
I was looking for this because I did not have the EDS file for the camera. I also just like to know what all the bits do sometimes. If you want to...
945
some of the existing ethernet IO modules having problems after adding couple camera(Keyence IV3).Tried swapping the switch with a bigger one...
1,641
I am looking for information on camera systems for monitoring machine lines. Does anyone have any suggestions? I have done this in the past using...
1,878
