Keyence CV-X Vision System to Micro 850
gedds1993
Jul 2012
South East USA
27
So I struggled with getting Ethernet/IP coms between these two devices for a hot minute. To communicate to the Keyence controller you have to use CIP Generic messaging. Long story short, hex from Keyence had to be converted to decimal (so that the UINT, USINT, and UDINT data types needed for the instruction in CCW would work) and you have to make sure to set the dimension of the data set to the specific byte size requested or sent as well as make sure the size of the data matches the data being sent/received. Some of you, I’m sure, would have figured this out in no time, but for people like me I will be making a video tutorial with example code. Expect the video soon. If you need help otherwise please feel free to post questions here and I’ll answer the best I can.
~gedds
Does anyone have some experience with setting up the output settings of the parallel I/O? I need the output to be high when the part is good and...
2,597
Guys I am in the process of installing a Keyence CV-2100 vision system. The only thing I need is to send a couple of Outputs to the unit and...
3,176
Hi, Does anyone have any experience using the PLC link function in the Keyence CV2100 Vision system. I need to connect to a Mitsi QJ71C24-R2...
9,733
I am a college student in my 2nd year of Automated systems and for my final project me and my classmate are looking to hook up a Universal Robots...
5,411
Hello, While searching for new controls engineering jobs/careers, I've noticed that many employers require experience working with vision...
3,541
