Jeep1987 Member J Join Date Dec 2014 Location Michigan Posts 2 Dec 11, 2014 #1 Anyone else get this code intermittently? It can happen once a day or 20 times a day... I know it's the drive enable...so is there a way to fix it...or just get a new drive? any thoughts or advice would be great. Thanks
Ken Roach Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Seattle, WA Posts 17,490 Dec 11, 2014 #2 Check, double-check, and triple check the wire connections and any physical contacts that the signal passes through. The Enable input really is the Enable input and if it sees even a momentary dropout of voltage, the drive will react to it.
Jeep1987 Member OP J Join Date Dec 2014 Location Michigan Posts 2 Dec 11, 2014 #3 Thank you I will....
