Kinetix 300 MotionView index distance
Sean
Nov 2022
Mayo
Hi all,
I have an Allen Bradley PLC which is connected to a Kinetix 300 drive.
I have been using MotionView to adjust the different positions for a servo motor.
I have been adjusting the "Distance" parameter in the Index section of the drive. (See Attachment).
My questions are; should this distance value be readable by the PLC or OPC?
Can I write to this value from the PLC?
What model PLC? If you're using a PLC with motion capability, you shouldn't need MotionView at all. If you're using a Logix class PLC (CompactLogix or ControlLogix), you can add the K300 into the I/O Configuration via Ethernet. The basic tag includes a few user defined integers that you may be able to map in MotionView.
Also can be done with Micrologix/Rslogix 500 through messaging.
https://literature.rockwellautomation.com/idc/groups/literature/documents/um/2097-um001_-en-p.pdf
page 214
Thank you both for your quick replies.
Apologies, forgot to mention the PLC is a 1768-L45 CompactLogix controller.
The Kinetix 300 Drive is connected to the PLC and I can see all the IO Assembly tags.
I have found that the Index tag ID I am looking for is 285.
I was wondering how do I go about creating a tag for this Index base address using messaging?
I am using MotionView Onboard (version 3.68) for Kinetix 300. MotionView asks me for a password for clearing fault history. I can't find any...
3,723
I am an automation technician working on Kinetix 300 drives with Motionview Onboard. We have two different setups; - Controllogix 5000 to the...
6,343
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
218
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
97
