Kinetix 300 Servo Drives
lostcontrol
May 2009
NeverSayNever
1,071
We are starting to use these drives, but I a bit disappointed with the IO connection options.
Apparently, the only 'approved' connector available is the ugly terminal block ' 2097-TB1'.
Looking at the spec's on the connector, it is a '50-pin SCSI'.
Surely, I should be able to locate this type of plug & make my own..?
What do y'all do?
Hi! I'm trying to communicate with an old Kinetix 300 drive that is fully functioning. Is there any library I can use to monitor this drive with...
426
481
Currently tinkering with a home project for a wood router lift machine using some second hand parts from a redundant timber mill. The servo is a...
2,432
Hello, I am using Kinetix 300 with CompactLogix (Ethernet IP) and it works well, but happened twice along one day the following situation: I...
1,982
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
