Kinetix 5500 Feedback Device Failure
Elcan
Apr 2008
NC
935
Hi all,
One of the Kinetix 5500 in a machine is getting a Feedback Device Failure, subcode 66: INTERNAL RESOURCE ACCESS ERROR.
Studio 5000 V.34
Kinetix Firmware V2.008.
Maintenance says they've changed the feedback cable. The fault is not happening in the other servos in the machine.
Any particular considerations when the sub code is INTERNAL RESOURCE ACCESS ERROR?
I found a tech note (access level: TechConnect):
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/700900/loc/en_US#__highlight
It says that there's a known anomaly with VPL motors where the drive shows " FLT S47 Subcode 66". The condition can show up and gradually worsen over time. Solution is to flash the drive's firmware to v2.008 or higher. It also says that v2.008 can show up as v2.8 or v2.08.
Thank you for the comment! I actually upgraded to V2.008 and the issue kept happening.
Hello all, new to the community! I have been experiencing an intermittent servo fault on a Kinetix 5500 connected to a VPL motor. Fault code...
25,360
Hi all, I am upgrading a couple of 2094-BC01-M01 servos with 2198-H015-ERS. The original code uses MSG instructions to control (release, engage...
70
Hello everybody, I have Kinetix 5500 (2198-H040-ERS). I'm having issue with this drive. (I believe it's the drive/Kinetix and need confirmation)...
60
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
189
Hi guys! I have 3 servos for X,Y,Z axis controlled by Kinetix 5500. In Studio 5000 there is one Predefined tag in AXIS_CIP_DRIVE called...
202
