kinetix 7000 tuning issue
rejoe.koshy
Dec 2011
kolkata
195
I am not able to tune a hpk series motor using kinetix-7000 drive via a 3MOSAE module.I fill in necessary details in axis tab & issue command for tuning.The motor responds accordingly but when the process is completed it says "tuning incomplete, process aborted".No faults are exhibited.
What could be the issue?
We have a tissue Embosser which uses AB Kinetix 7000 drives and HPK servo motors. This particular fault concerns a 2099-BM07-S drive controlling a...
2,551
2,621
We have a Kinteix 7000 that is used in a winding application. About a month ago we started having issues where the drive will get a stop command...
6,091
Hi, I am facing a problem in my cut to length line servo system, problem is such that whenever i am running more then 1.5 mm thickness material...
2,518
I have a kinetix 7000 servo drive installed at my end which has suddenly started malfunctioning .It displays a fault code E62 when ever MAM...
4,086
