Kinetix Torque Control
chawkey
Jan 2023
Michigan
Hello,
I have an application where 80% of the time, an operator will be needing to issue very accurate MAM or MAJ instructions to a Kinetix 5500 servo. This works exactly as expected when setting the drive configuration to position loop.
However, there are times when they need to jog the drive but hold a certain force (torque, current, whatever). That is where I learned about SLAT control, and how it might be my best option.
But in order to use SLAT, I have to set the servo to velocity control.. which is fine except for the fact that all move and Jog commands are now off by 5-10%. For instance in this configuration, a move to 20” would stop at 18.6”. This would be unacceptable.
I also know that you are able to switch between the two modes via SSV’s , but in order for this to work, I have to reconfigure the drive to be back in a position loop by default, then I can “degrade” the control to velocity for SLAT control while running. But doing this removes access to the SLAT configuration parameters in SSV’s (they are only valid parameters when configured to velocity mode). So I’m stuck spinning my wheels here..
The application is not a typical winder application, there will be no web breaks, so maybe SLAT isn’t necessary? Can I just simply keep the servo in position loop, issue a MAJ but perhaps change some torque parameters to hold a torque when presented with a mechanical limit? Now in this mode, I honestly don’t really care what speed it goes at.. only that it is accurately holding a certain force.
Any thoughts would be appreciated. I feel like I’m stuck between a rock and a hard place with my perceived options, and calling Rockwell is my next step after this.
Thanks all
Hi All, Was hoping someone would be able to offer some pointers on a setup I am working on. I am well versed in PLC programming however I have...
7,820
Want to limit torque on a servo motor (Kinetix 6000 w/ contrologix PLC) so it will stop if there is an obstacle on the travel path. What's the...
4,381
Hi All, I have a large servo indexer chassis that uses an AB servo and Kinetix 5500 drive. It seems logical to me to try to limit the amount of...
2,114
I have the Kinetix 300 drives and control logix L63. The communication with ethernet. How the get the torque from the Kinetix 300 drives?
2,949
I real need you help me.:bow: I have the controllogix 5563 and communication with Kinetix 300 via ethernet. Currently, all communication is ready...
5,042
