How to get the torque from the Kinetix 300
Xu MingJiu
Aug 2017
Shanghai
I have the Kinetix 300 drives and control logix L63. The communication with ethernet. How the get the torque from the Kinetix 300 drives?
Would it be MyServo.LoadObserverTorqueEstimate
Also read this in one of the manuals:
Kinetix drives use current sensors to measure motor currents which can be used to estimate (approximately) the motor torque, since torque is related to current through torque constant (Kt). Thus, if you use the current signals and Kt, you can get a good estimate of the actual motor torque, but only up to motor rated current.
Hi Jax
Thank you for your reply. But I don't know what about MyServo.LoadObserverTorqueEstimate. Where are this parameter?
Could you share Demo program to me if you have.
I try to test program. But I find. if I used L63 of ControlLogix controller. The configuration in the Studio 500 just only has 2097-V33PR3. If I used L36ERM of CompactLogix controller. The configuration in the Studio 5000 has 2097-V33PR3 and 2097-V33PR3-LM for select. I don'w know what's the different.
I real need you help me.:bow: I have the controllogix 5563 and communication with Kinetix 300 via ethernet. Currently, all communication is ready...
5,047
Could someone please explain what is the purpose of the "safe torque off" feature in Kinetix 300 Drive. I am in situation where I need the k300...
3,566
Hello, I have an application where 80% of the time, an operator will be needing to issue very accurate MAM or MAJ instructions to a Kinetix 5500...
708
Hi All, I have a large servo indexer chassis that uses an AB servo and Kinetix 5500 drive. It seems logical to me to try to limit the amount of...
2,117
Hi All, Was hoping someone would be able to offer some pointers on a setup I am working on. I am well versed in PLC programming however I have...
7,825
