Kinetix 300 Safe Torque OFF
msajid
Jan 2014
canada
25
Could someone please explain what is the purpose of the "safe torque off" feature in Kinetix 300 Drive.
I am in situation where I need the k300 to stop when it hits certain torque, Is there a way to achieve this on this drive?
All your help is greatly appreciated
What you are trying to achieve would not be achieved with "Safe Torque Off". Safe Torque Off is used to remove power from the Motor without removing power from the Servo Drive itself thus allowing for quicker recovery for an E-Stop situation where the Safety Relay cuts the power to the motor.
What you are attempting to do is effecively limit the torque which can be applied. This is something that you cannot really do very well in a Kinetix 300, its easier in a Kinetix 350 or Kinetix 5500 drive.
Regards
Ian
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
37
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
161
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
249
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
108
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
439
