Klockner-Moeller PS31 PLC
heutinck
Mar 2004
Hi I have a customer who has come to me with an issue with his Klockner-Moeller PS31 PLC. I realize its pretty ancient and should be replaced, and I believe he intends to. But at the moment they are having an issue with the program in the PLC and asked if I can help them. I know that it requires the CoDeSys software to program it, but are there version limitations? does the newer versions support this PLC, and also is the programming cable anything special, Null Modem or straight thru?
any help is greatly appreciated. Thanks
it is not codesys, and you will need to have the original files to go online and check and edit.
Same as on newer systems, as it is compiled.
In PS3 it is not compiled.
and yes it is ancient.
I am looking for leads on getting a manual in English for the Klockner Moeller VTP HMI software. The software is VTP and was DOS based. From what...
563
Hi. I have a program that is from 1988. It is written in IL and I cannot find manual for it. It is PS32 PLC. On vendor site...
1,553
One of my customers purchased a used machine with a Klockner Moeller PS4-201-MM1 PLC in it. The program was gone, but they were able to obtain the...
3,355
I am trying to track down the hardware and software to get online with an installed Klockner Moeller PS3-DC PLC. I wish to gain the means to get...
2,374
hello Gentelmans, Is there a first scan bit in Klockner Moeller EASY PLC?
2,804
