Know-how protection TIA portal
Purple_Lisa
Dec 2011
Israel
19
Hi all,
I have several blocks that we built before many years and they*have password protection.
The problem is that we had lost the password and nobody remembers.
How can I solve this issue and open the block ? may be I can reset the password somehow?
Thank you.
With Step7 it was easy, But I think Siemens made a bit more difficult with TIA. However that's not discussed on this forum.
Don't think you can reset the password as that would defeat entire purpose of the password in the first place.
I haven't heard of any ways to bypass the knowhow protect in Portal, but as DeKemp says, that is mostly taboo in this forum.
It's too late now, but I always recommend saving a version of the project with no blocks locked, as a backup.
I always saved them in text format in word as a library.
OK, :oops:
Thank you.
All, We are looking into the best ways to protect IP in PLC/SCADA code and the latest offerings included with TIA portal seem much better than...
3,928
Overhere we bought a machine with an CP1542-5_1 PLC. I need to make some changes in the software, but the blocks (OB,FC,FB and DB's) are know-how...
6,905
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
204
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
180
Let's say I have an inverter fed three phase induction motor drive where in the braking phase (when the motor operates in a generator mode) the...
144
