L71S and Point Safety Outputs
padees
Aug 2011
Michigan
909
Hi all,
I just got back from looking at a project upgrade in the works that the manager is having his buddy do.
It is using an L71S with Point I/O. All the inputs are standard inputs from proximity switches and such. All the output modules are Point safety outputs directly wired single point to loads such as contactor's, solenoid valves...
Just wondering how the heck you do that and call it safety?, or even make it work?
This is a Roller Coaster upgrade, and this company has never done one before.
I am a safety geek. So keep that in mind. I have been called several time to look at safety jobs where good "old joe relay" has made it safe .
I went on a job a once and they use safety contactors and told the customer it was safe.
Another job the customers head safety person said they where upgrading all the PLCs in the plant to safety. This was after an accident. They where using these new red PLC. They where just Mitsubishi PLC with red power supplies w\standard I/O.
50~75% of my safety conversation with customers are why we can't just use "120 VAC like we always did before"
I feel you pain.
I have seen several roller coasters that where either no safety or safety to the max. Most State ride inspectors never look at the controls.
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
67
Hmmm... The Auto Discovery was working well until I got to the last two cards. Then I got this: "device cannot be added because there is no room...
750
Help required For Guard Logix CPU L71S We are facing following problems for gurad logix 1) How we can edit the safety Program and safety tags...
2,459
Good day to all! I came across an interesting problem yesterday and cannot seem to resolve it, so I am hoping someone may be able to shed some...
6,761
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
75
