John Soltesz
This was called "Mnemonic Code" when TI sold these processors, TI405. In TISOFT 2.0 you could write and edit in this code. It also was used to convert a 5TI RLL to a TI435 processor. The VPU for a 5TI could output a file in "Symbolic Code" (same thing as mnemonic) then you would run a conversion utility to download into the TI435 that was connected to the old 5TI I/O. I've converted several this way.
I started out in electronics in the late 60's then got into electrical controls that only used relays. So it is burned in reading ladder prints of hardwired systems, mostly locomotives. I had one quarter of FORTRAN and a quarter of machine code a decade later, hated it. I didn't touch a PLC till the early to mid 1980's, very early TI. I mostly program AB now for in house projects.
Our techs only understand RLL; some even have problems with that. It is rather hard in our area to find competent electricians that can be good at more than RLL.
I’ve done some flowchart (OPTO22, don’t like OPTO22 for other reasons) and a bit of Function Block. If it is in RLL then I don’t get calls at home is a quite valid statement. I almost never get calls about my systems. It is usually from another companies design.
Our rolling mills use GE and we have an engineer on site to handle those issues.
geniusintraining said:Hi Peter,
Here is another version of STL by Automation Direct, I have now idea of why they have it, I don't think you can edit it just view but not even display the RIO, I'm thinking that you may be able to edit something like a CSV then import... I have not tried it yet
The reason I have gone from 60% STL to 40% is the additional PLC's added in the last 5ish years, I have added aprox 30 more none have STL, so in other words no S7's have been added only AD, AB's and Mitsubishi, soon I will get a S7300 very soon,
I love learning... or torturing myself
