ladder for control stepper motor with 2 sensors
OK Berliyanto.
Here's ladder to control a stepper using two sensors. One sensor senses a pushbutton labeled "Start"; the other sensor senses a pushbutton labeled "Stop".
Start Stop Stepper Run Command
Stepper Run Command |
Somehow, I think it's less than you were hoping for. For a better answer, ask a better question.
what more input U mean
Well Berliyanto, I do mean a lot of info.
A. Regarding the stepper motor:
  1. What drives the stepper motor: a dedicated driver or a bunch of PLC outputs.
  2. What kind of stepper motor do you use:
    - Unipolar or bipolar
    - Number of poles[/list=1]
    B. Regarding the sensors:
    1. What is the purpose of each sensor?[/list=1]
      C. Regarding the control::
      1. mode: full-step, half-step, micro-step?
      2. speed?
      3. direction: single direction or bi-directional?
      4. travelling length: number of pulses or commanded by sensor (see also B1)?[/list=1]
        Once these questions are answered we can help you further. Without this info, any help we offer is bound to be useless in one way or another.
        Regards,
You are boring Mike.?
The guy hardly speak English.and he is not polite too.(The word Please is master key.But not in his dictionary.)
Any how let us help him gently.
to arikBy
Hey Arikby, you still not undertand then american thinks they are the belly button of the world!!
Bush is the man......to destroy the world :(
to answer Mike
For thoes of you not famillar with the Abbot & Costello rutine, I was only jesting at the first three posts.
The first post was so vague that any direct answer would be a shot in the dark.
The second post requested more "input" meaning more infromation.
The third post seemed to think that this was the answer: "You Need More Inputs". Hence, the obivious misunderstanding of the context of the use of the term INPUT.
There was no disrespect intended; and I commend jvdcande & Steve Bailey for taking a shot at attempting to answer such a vague question.
Mike.
"Hello, I am a beginner learning about PLC. Could you please give me some advice? I want to write PLC instructions as follows: When the sensor...
18
3,426
Old Allen Bradley guy here: I used to have a SCL or SCP and then a PID tuner block to use. Here in the FANUC ladder world I have not been able to...
1,873
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,893
i need to control six pump sets. initially 2 pump sets will run after two hours another two will run and later the third pair. 5 bar pressure...
26
13,631
Hi All, I'm fairly experienced in Allen Bradley PLC programming but have come up against a problem I've not encountered before and wondered if...
8,393
