There is Mike , read it again - the PC being backed up must be shut down and restarted in PC dos mode , then there are no active services , no swap file , no possible sharing violations , nice and easy , I promise you , it really does work , but like everything else , take your time , otherwise you will make a cobblers of it -
By the same token , obviously you can't save the image to the partition being backed up , otherwise it would disappear up its own SCSI - but this is self explanatory .
If you have a basic knowledge of the way windows and dos works , the you will get ghost to run with no problems .
