Laptop IP address info needed
stu
Aug 2005
England
784
Hi guys
I have a company laptop which we use a IP address to connect to a servers say 172.16.23.###
And I use a lot of different IP address on the plcs in the advanced setting in network lan 192.168.1.254,192.168.2.245, 192.168.3.245, 192.168.4.245, 172.16.23.245
I have an issue where I need to switch between the network how can I get around this is ? I have heard about bat files? But will that company into the advanced settings.
Any help will be appreciated thanks stu
I use these two:
fixed.bat:
Code:
@echo off
set /p name= IP address?
netsh interface ipv4 set address name="Local Area Connection" static %name% 255.255.255.0 0.0.0.0 1
pause
and
dynamic.bat
Code:
@echo off
netsh interface ipv4 set address "Local Area Connection" dhcp
pause
To add an additional IP you need this syntax
Code:
add address [name=]InterfaceName [addr=]IPAddress [mask=]SubnetMask [[gateway=] DefaultGateway [gwmetric=]GatewayMetric]
So maybe
Code:
@echo off
netsh interface ipv4 add address name="Local Area Connection" 172.16.23.245 255.255.0.0 0.0.0.0 2
pause
Change "Local Area Connection" to whatever your interface name is, or change your interface name to match the bat file
You need to run these .bat files as administrator.
I use NetSetMan http://www.netsetman.com/en/freeware
You get a certain number of tabs for free (6). If you pay for the Pro version you get unlimited tabs. No adds or anything like that for even the free version. It is a good tool for people that have to take their laptops to different locations with different IP's.
+1.
I've been using it for the last 4 years or so.
Not a single issue.
Does anyone use any software to easily change the IP address of your computer depending on what machines you are working. For example, you can go...
4,503
IT has adoped a hardline policy - I cannot change the IP address on my laptop and they have locked it down - its set to get a dynamic IP address...
25
8,888
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
123
Hello all, Hope everyone enjoying their weekend. I just recently bought a laptop to upgrade my old one with i3 its getting slow on me. But when i...
403
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
134
