Latching and UnLatching in Modicon 984 ProWorx
JuNGLisT
Sep 2003
North Carolina
31
We have a simple circuit that we want to latch and unlatch. The ProWorx software offers a Latching Coil -(L)- instruction, but we have no clue as to unlatch. I searched the forum here and read the manual and the help section in the program, but to no luck. We anybody have any knowledge about this?
Hi
I'm afraid you'll have to do your latching the 'long' way on the Modicon...it doesn't support set & reset of discrete coils....
The -(L)- coil is a retentive i.e it remembers its last state after a controller
power down.
regards
Kevin H
www.krkautomation.com
......although if you r_e_a_l_l_y want to use S/R and you're using a Quantum, you can set & reset the bits in a 4xxxx register using SBIT & RBIT and test for them using NOBT & NCBT....
984 Ladder Logic is the base language of the Proworx, Modsoft, and other software packages (except Concept and Unity). 984LL does not have Set or Reset coils, you need to create your own logic. However the Quantum family of processors has an enhanced function set which includes these functions using the SBIT and RBIT commands.
ADVISORY: The 984LL -(L)- latch coil does not behave like a most retentative coils. You still need to create additional logic to get a true retentative coil. If the -(L)- coil was set at the time when the processor cycles down it will only be set for one scan at power up.
For a true retentative set-reset operation, of coil 0x1, I have used this logic.
SET RESET 0x1
---][--|-]/[--------(L)-
0x1 |
thanks for the inputs, they have been helpful. with creating some new networks and adding some instructions, we've accomplished what we aimed for. prety much did what Jim Dungar was stating. thanks again for the info.
I'd like to get some feedback on the use of latching/unlatching relays. (Something I've never used in my limited programming experience.) I've...
4,854
I am looking at some AB RSLogix5000 controllogix code. A very simplified sample of code written within the same ladder...
3,078
Hello everyone. I'm new to TwinCat 2 and was wondering if someone can tell me the AB equivalent of a TwinCat Latch and Unlatch? Also, is the...
2,363
Hello again, everyone. Could anyone help me understand the best way to handle state transitions in ladder logic programs with Studio 5000? I...
3,238
Nubee question on latching and unlatching relays I have a customer with a Data center configured like below: What I am trying to do is: If...
2,796
