Lauer BCD verses Hex + S7 300 crash
kevbloke
Jul 2004
Kent uk
81
Guys, I have an issue that i dont understand and am hoping that someone has an idea.
I have a Lauer PCS950C HMI communicating with a Siemens 315-2DP CPU. The machine is a labeller putting plastic labels on a PET bottle.I am trying to adjust a cam setting (glue roller in)this is normally done on the HMI but this hasnt worked in a long while i have been informed. My boss said that my predecesor pluged in to the PLC and changed things to adjust cams!
The value i want to adjust if things were normal is a value of 150 on the HMI. The HMI is sending this to DB50 in BCD form. The value in DB50 however is prefixed W#16#150. I thought this was a Hex number. When i modified the value to something else the plc crashed and told me that it is looking for a BCD number in Accu1.The next step in the program is the value from DB50 gets processed as below:-
L DB50.DBW450
BTI
L 1000
*I
T DB11.DBD 0
DB11 then has it a DINT L#225000.(what does the L# mean?)
The cam card is a FM352 if this helps
Any help much appreciated please.
Kev
If DB50.DBW450 contains W#16#150 = 336 decimal, then DB11.DBD0 will contain 150000 as shown below:
Thanks for your help guys.
Why does the plc crash when i alter the hex number? I would have thought it would carry on with the maths in the FC
Kev
BCD codes each 4 bits as a decimal digit, hence only the numbers 0..9 can occupy the four bits. If A..F occupy the 4 bits, this is not a valid BCD number and hence the plc exception.
Can you explain why you have 225000 in DB11.DBD0 as this implies you have W#16#225 in DB50.DBW450, not the W#16#150 you state?
Can you explain why you have 225000 in DB11.DBD0 as this implies you have W#16#225 in DB50.DBW450, not the W#16#150 you state?[/quote]
That was my bad, i was looking at the wrong line in the DB.
What i have found out is that the values are changing with the HMI but the cam itself isnt updating. I dont think the values are being written to the cam controller. When my boss said my predecessor plugged into the plc to change the cams i think he meant the actual FM352 card if this is possible.
Thanks for your help chaps
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,154
Hello everyone, help with information documentation for 2 line display LCA 400. Couldn't find anything on the internet about this model. When the...
1,596
Hello, I think this might be my first post. I have a client who has a broken Lauer LCA Panel, and fortunately they own another panel with the...
3,012
I have to replace a Lauer PSC090m HMI. It is a PCS090-Plus and the 'm' is for Siemens MPI communications. I have PCSPro and the PCS733 cable and...
2,973
Hello, We have for over 20 years on one of our devices LAUER PCS 950 panel, connected to the PLC S5-115U. 2 days ago after switching on the...
1,618
