Launching RSLogix Maximized when clicking on a file?
donl517
Dec 2005
Michigan
127
Is there anyway to get RSlogix 500 to always launch maximized when clicking on a file in windows explorer? I find I have to click on the file, Maximize the window and then arrange the window to a default project. PIA
TIA,
Don
TIA,
Don
There is an option somewhere - where you can specify the settings. I don't remember and don't have the software right now, to check. But try one thing:
After you open the ladder file, drag the borders to maximum size (Don't use the "Maximise" option on the menu title bar). And then arrange it to default. Save and close the file and try opening next time. This should also work.
Let us know the result.
--Rahul.
A Shortcut can be configured to run Maximized, but I Don't know how to do that with the Executable.
I guess you just get in the habit of double clicking the Blue Bar on top?
Rahul,
That seems to work OK.
It seems there would be a registry setting somewhere that would force it to launch Maximized.
Thanks,
Don
Thanks, I know how to do this, but it doesn't solve my problem.
Don
Yes wouldn't it be nice if you could do the same with the Rslogix .exe file.
You could try one of several types of shareware programs like
MaxMonkey 2.40
I am not recommending it though, because I don't think that I would try it.
Good Luck
gbradley
Hello Folks, Has anyone has success launching Windows Explorer from ME Program Launcher ActiveX? I would like to be able to open Windows...
1,551
Hi, I'm trying to display a popup in FTview when a PLC tag reaches 0. Then you have to hit a confirm button to close the popup. I should probably...
1,398
thought this would be easy.... working with Factory Talk View SE 6.10 I have a string input where my operator inputs a date in the format...
3,473
Hi guys, It is possible to execute the Excel.exe when I click the button at RSView32? Is there anywhere we can do this without doing any VB...
6,308
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
