LED Numeric diplay help
AAJ
Feb 2007
Wisconsin
Hello to all, this is my second post so I am new to this format.
I have a PM 90 volt 1/12 hp gear motor that works great with a small Dart control. I want to try to apply a 1/2 inch high LED two position surface mount display to show the RPM on this small turntable. The final RPM is 0-4. The machine has a 94 tooth steel
gear that I could use with a prox. or reed switch. Here is my question. Is there a small display with appropriate power supply
available to apply to a turntable like this? Can I use the position of the speed pot to drive this? Are there companies out there that will talk to small OEM's about this request? Looks like I will use 75 - 100 a year if I can keep cost down.
Sorry for my lack of knowledge, beginner here. Yesterday, we had a Pro-Face SP5000 HMI fail on us. The technician said that the HMI had the blue...
148
hello I have 7cp476 cpu why can led always open and No connection
148
Why AMIo800 Analog input module's I/O LED is Lighting up Red? Checked module connections, 4-20ma wires etc but this light is continuously Lighting...
124
Hi everyone, I got a Parker HMI, CTC PA2. I tried to download program to it but it froze in the process and could not finalize. Now, when I try to...
55
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
279
