lenze 8200 vector setpoint via profibus dp module
benji
Oct 2008
syria , Aleppo
72
as it says im trying to send data to the inverter from my plc
apparently when it commes to the process data channel there are more than one way to send data
there is DRIVECOM and PROFIDRIVE and UNIT CONTROL
why is there more than 1? what diferences are there among those?
Hi
In the attachement you have an example how to communicate with a 9300POS. I hope it helps.
It's the S7 project and the GDC file.
In the example you have: the control word, status word, position set, position receive, and an example how to do a parameter request read/write.
If you have questions, I can help you further.
Kind Regards,
C
I have an issue after programming a Lenze 8200 Vector drive using Lenze Global DRive Easy software. I have connected using a Can Bus interface...
590
Hi, Friend i am facing trouble with Lenze vector 8200 drive, when i try to download the program in Drive, a pop-up window appears & showing "For...
4,143
Hello everybody, Is there anyone who has experience with 8200 vector?? I have six winder machine,working without problems for some time.I always...
1,487
Hi friends, I'm in a tight corner here with a project deadline at the door step, and in need or desperate help. Originally the project was to use...
8,673
Please help me how to connect Lenze vector 8200 + Lecom communication modul+ computer to upload parameter from Lenze inverter 8200? I did try to...
7,956
