Lenze L-Force Motion Controller and SLC500 Communication via Ethernet
eandr
Jun 2009
Lancashire
Has anyone got any suggestions or ideally a working example of how to exchange data between a Lenze L-Force Motion controller (CoDeSys based IPC running WinCE) and an Allen Bradly SLC5/03 PLC over Ethernet?
I have talked to AB/Rockwell, Lenze, 3S and Beckhoff and all have drawn a blank. I know of two really awkwardly messy ways of doing it. One would require an embedded PC running WinXPe and I can use an OPC driver and a VB program to talk to both systems, the second way involves communicating via CAN and Devicenet, but is limited on the infomation I can send.
I have previously communicated directly from a Beckhoff Twincat IPC (also running CoDeSys) and a Siemens S7-300 which worked really well, but struggling with the Rockwell option.
Any suggestions?
Hi for all, Maybe anyone knows RJ45 10 pins wiring for cable? It using for Lenze L-force Drives diagnoctic. USB diagnostic adapter I have,but I...
2,661
Getting back into the controls field after a long hiatus going to school. Due to unforeseen circumstances I have been suddenly placed into...
3,209
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
90
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
242
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
186
