Lenze LECOM A/B module EMF2102IBCV001 compatibility
gaminn
Nov 2023
Czech Republic
I used to use my Lenze EMF2102IBCV001 LECOM a/B module to connect to many Lenze 9300 series servo drives. Now I would like to connect to Lenze 8200 vector inverters (E82EV371_2C, E82EV552_4C) and I'm not able to establish the connection. When plugged in the Lenze 8200 inverter, LECOM module doesn't even light up its green power on LED.
I use Lenze GDCEasy 4.14 software.
Can you please help? Is EMF2102IBCV001 compatible with Lenze 8200 vector? What module should I use to connect Lenze 8200 vector to my PC?
Martin
IMG_20231124_115810.jpg IMG_20231124_115828.jpg IMG_20231124_115853.jpg IMG_20231124_115901.jpg
OK, so I discovered Lenze 8200 vectors have a jumper on the front panel that sets power supply to module connected to the front panel. I set the jumper correctly and now power on LED on the LECOM module lights up. However, GDCEasy still doesn't recognize my inverter. The inverter is set to C0125 = 4 (baud rate = 19200 baud) and C009 = 1 (device address = 1). GDCEasy finds something at 19200 baud rate but then it probably sweeps through device addresses from 1 to 99 and finds nothing. RX LED on LECOM module blinks during that.
I have a customer with a washing machine that is using a control system that communicates with a Lenze 8200 drive via Lecom AB. As the replacement...
4,985
Please help me how to connect Lenze vector 8200 + Lecom communication modul+ computer to upload parameter from Lenze inverter 8200? I did try to...
7,983
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
53
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
99
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
249
