Level in Tank Control?
martin1
Apr 2008
Britan
43
Hello,
I am looking for advise on how to write some code (Ladder Logic)
I want to control a dosing pump based on the volume increase in a tank.
When the volume in the tank increases by 5mm, turn on the dosing pump for a set number of minutes.
The only way I can think of doing this is within a specific time frame.
What platform are you using?
I think you are correct. Or perhaps you know there will be breaks between the increments.
Will you only have an increasing volume?
Might this be a homework assignment, I think I have seen this question before?
You could always take the sample when you stop running the pump then compare it, issues arrive when you are taking out from the tank though. Just find a suitable trigger to store the value
Ash
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,561
This video shows the things I think about on page 1. I use Laplace transforms a lot. Laplace transforms allow one to express differential...
1,808
New to group I've seen well pump controllers with analog circuits that pump till sensing a current drop then start a timer. Seems an opportunity...
2,710
We have a few filling machines at work that utilize 2 normally closed capacitive sensors emulating float switches. These machines are relay...
1,543
Oh No! Not that again! I will start out sort of simple ( evil thoughts ) Suppose I have a tank that is 4 meters tall with a constant surface area...
7,419
