Tank level control
EMurphy
Sep 2015
Massachusetts
We have a few filling machines at work that utilize 2 normally closed capacitive sensors emulating float switches. These machines are relay controlled.. No plc. I have no ladder diagrams. I have had to construct a similar system to keep a tank full. It's basically a standard seal in circuit. Question is these sensors are 2 wire types. So there's 2 sensors in series before the coil. I'm using a 78 series automation direct relay. Is there something I should know about here. It appears the relay light is always on. Although dim. I don't have much experience with 2 wire sensors in series. Thanks for any help
There are a couple of things you should know. First, there is small amount of current flowing through the sensors in the off state. That may be enough to make the LED glow, although not necessarily enough to energize the relay coil. The data sheet for the sensors should tell you the magnitude of this leakage current. You can compare that to the minimum current to switch the relay. Second, there is always a voltage drop across the sensors in the on state. Wire too many of them in series and eventually the voltage will be lower than the minimum required to switch the load device. Again, the magnitude of the voltage drop should be on the data sheet for the sensor.
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,562
This video shows the things I think about on page 1. I use Laplace transforms a lot. Laplace transforms allow one to express differential...
1,809
New to group I've seen well pump controllers with analog circuits that pump till sensing a current drop then start a timer. Seems an opportunity...
2,712
Oh No! Not that again! I will start out sort of simple ( evil thoughts ) Suppose I have a tank that is 4 meters tall with a constant surface area...
7,421
Hello, I am looking for advise on how to write some code (Ladder Logic) I want to control a dosing pump based on the volume increase in a tank...
1,727
