Level Measurement Formula
jose7771
Jan 2005
42
HELLO FRNDS
I AM INTERESTED IN MEASURING THE HEIGHT OF A LIQUID IN A TANK OPEN TO ATMOSPHERE ,BY FLANGED TYPE DIAPHRAGM TRANSMITTER ,THE FLIUD BEING DIESEL OIL.WATS THE EXACT FORMULA FOR
MEASURING THE PRESSURE, IS IT
H = P/SG
H = HEIGHT , P= PRESSURE SG = SPECIFIC GRAVITY
OR SHOULD I CONSIDER GRAVITY ALSO
P =H *RHO *g
h =height rho =density g =gravitonal force
regards
jose
You could do it either of those ways, although I'm not sure if the calculations you have are right. But the way I've done it in the past is by putting in a known amount the first time, note the pressure, and use that as a starting point.
It depends on the output scale of your pressure transmitter. If the output is inches of water, then h = P ÷ SG where h = height in inches, P = pressure in inches water, and SG = specific gravity.
If P = 27.7 " H2O and SG = 0.80 then the height is 34.6 inches of fuel oil.
On the other hand, if the output is in psi you need the density term. h = P ÷ rho
If P = 1.0 psi and rho = 0.0288 lb/cu in (49.92 lb/cu ft) then h = 34.6 inches of fuel oil.
A very handy trick I learned in ancient times (college) is to write out the formula and make sure the units cancel out properly. In the case of the second formula lb/sq in ÷ lb / cu in results in units of inches (1/1/in = in). Having the right units doesn't guarantee the formula is right, but having the wrong units guarantees the formula is wrong.
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,548
I want to measure the level of water inside a closed st.st tank with an over flow opening in the top of the tank at the begining of filling the...
16
4,732
Hi, i have a problem with measuring level in silo using siemens S7-1200. On top of the silo there is an 0-10V radar level sensor, it works...
3,666
I am looking at a Small Boil-off Tank (5' High) rectangular, and need to do some level measurement. The current tank has an opening at the top, so...
1,873
hey guys, I was asked to monitor 4 big tank of water (around 3000 to 6000 usgal) those tank have no mixer in it only water for our cooling...
1,994
