Hi guys,
Appreciate it if someone has experience in these application can give me some feedback.
For application A, the 1200 liter Tank containing IPA solution, I want to get a device which can give me level indication (low, high & high high). I do not need to know the volume or exact liquid level, I just need the level indicator back to my PLC to start/stop some pumps & valves. The tank is stainless steel. Please suggest a suitable device to do this.
For application B, the stainless steel panel must be pressurized with N2 gas (one of the customer spec). The panel pressure must be higher than atmosphere so that outside gas will not enter into the panel. Is there a device to measure the N2 pressure which will be mounted outside of the panel? I don't need these signal to PLC, just for the operator to view at the panel itself. Either an analog or digital also can.
Hope to hear from you guys. Thank you.
