Light Curtians
Johnny Rotten
Dec 2004
Ontario, Canada
194
Have been asked to look at possibly using more light curtains on more of our existing equipment. All of the plc's in our plant are Automation Direct, so I imagine I will use the light curtains from them, and use a safety relay to inhibit as needed. May use a plc for annunciation - which location etc. Does Automation Direct not make a safety plc that would bypass the need for the safety relay? Any generic thoughts on the subject would be great, thanks.
John
AD does not make a safety PLC. There are a few companies that do but they are generally very expensive.
I've used the AD curtains before and they worked well. I paired them with one of the LG5925-48-900-61 safety relays and initially had some issues with the relay latching occasionally (you could reset it by tapping on it). Turns out I had a bad unit and AD replaced it very quickly.
If you can provide more details on your application that would be helpful.
I also have good things to say about the YBB-30R4 series, I have used several lengths. I used them with some AB safety relays my company bought before I arrived here
Hello all. We have a slight problem. Shcneider Magelis back light burned out and now it is very difficult to operate. There seems no spare parts...
102
Hello everyone. I am working on designing a call light/alarm system I have roughly 20 stations that will each have their own call switch. Then...
20
528
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
123
Hi to all. On our Siemens PLC power supply, the battery light is showing amber. If we do not immediately change the batteries, will we lose the...
144
Hi all, I have a question about light towers, the way I have always used them and the way I was taught is like indicator lights, i.e. Green...
361
