light sensor 4-20 mA or 0-10 Vdc
ungaro
May 2005
Lokeren
72
Hi, can anyone get me a circuit drawing for a light sensor with 4-20 mA or 0-10 V output. Supply voltage should be 24 VDC. I want to connect this to a analogue plc input to control the outdoor lights with it. I looked on the net but seems hard to find and i don't have the knowledge
??????? how do we supply schematics when we don't know what sensor your using? Plus if you have a particular sensor you can get the data sheet by entring the part number on the web. Or is your question that you need to find one that suits your needs if so we will need further info such as sensing distance, type of sensor (thru beam, retroreflective, diffuse, light mode or dark mode, npn or pnp sink or source ie do you want a 0 volt active or a 10 volt active. 4-20 MA sensor sounds like a distancing sensor is this what your looking for??
Hi I have an application where i need ambient light sensor. While I can use sensors like BH1750. I am not sure how i can use it in an industrial...
632
Hi, I am trying to find a light sensor with either a 4-20ma or 0-10V output. I have searched google but couldn't find anything suitable...
2,869
I am designing a test box that will do a functionality test on incandescant lamp fixtures. I am looking for an "off-the-shelf" light sensor. This...
6,274
L
how to connect light depedent sensor to PLC ??
3,179
Hi guys and gals have a question: I'm currently a student and just started taking a class on PLCs. So this is my first time doing Ladder Logic...
8,069
