Line filters control panels with PLC equipment
irondesk40
Jan 2008
nc
630
Curious.
What brand of main control power such as the incoming single phase or 3 phase power does anyone recommend? Also, do you use a seperate filter on the output of the 24vdc power supply?
Lately we have been using the micrologix 1400 plc that is powered off the main line voltage and starting to do a lot with analog and wondering if best pratice would be to start using a main power line filter.
thanks
The incoming line voltage for the equipment we have been building is single phase 208
what i have used on the last couple of projects is a Roxburgh DRF10 which i purchased from automation direct and run the main line voltage into it and the output to the control power input for the power supply and the PLC.
I'm having some difficulty figuring out when an AC line filter would be appropriate for an application. What exactly is being filtered, the...
2,348
In a system where the main power supply is 120 VAC, how common is it to use a line filter in the control box? This machine is NOT in an...
1,423
I have been using Islatrol line filters on the machines that i have been building but curious as what brands others may be using.
1,433
Hi all, i am working on a project in which i need line filters on the 110 side of the controls. my search for line filters gave a wide range...
3,014
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
58
