Linear Actuator Control
Johnny Rotten
Dec 2004
Ontario, Canada
194
I have a SMC Linear actuator rated at 24vdc. 2 wires, do I assume I apply 24vdc to make it go one way, and reverse polarity to make it go the other? I don't know much about them. Do I control torque by controlling voltage?
John
Smc lzbb3l-100a3.
Our millwright ordered it without the controller or anything, I just wanted one to play with. All the instructions refer to a controller but I wanted to perhaps make one myself. Two wire - blue and red to the motor. Rated at 24vdc.
I believe the SMT electric cylinders are usually being used connected to a SMT LC3F2 directional control driver sized up according to the respective cylinder's motor size.
See pages 20-23 of
http://content2.smcetech.com/pdf/LZ.pdf
There isn't much information out there, however, the LC3F2 is a simple DC drive which provides user control inputs (including thrust command switching between 100% and a user set value) and motor protection.
That's perfect. I suppose I'm going to make my own control driver and control the pulse width (time) of applied power depending on where a certain process deviates from a set-point. Time to play!
It is not spring return, and as the motor is permanent magnet, shorting the two leads together makes it hold - much better than not shorting them - puts motor in regen.
Will keep you updated - thanks and Happy Friday!!!
Hi all, I have a tricky controls task to implement that I could use some input on. I have a system using a trap-screw linear actuator that...
42
12,748
Hi, We want to buy a linear actuator 24VDC. We want to control this with a circuit board fro electromen...
2,325
The below text is a copy of a web site I just created (1-8-03) to find information on how to solve a seemingly easy but diffcult problem of...
39
11,252
We are looking for using a linear actuator, with stroke of 780 mm, with force of 2000 to 10000 N, and powered by 24V. It has to be industrial...
896
A R&D project, designing sort of a DENSI-METER (hardness tester), to check density of soft products. Looking for a compact version of a motor to...
2,306
