Linx Classic to Linx Enterprise transfer
careed_25
Jul 2007
KY
57
Is there an easy way to transfer the topics I configured using classic to enterprise. I have all my tags within studio se using the topic I configured in classic. I was wanting to copy these topics to enterprise and use that data server since it is more dependable. Will I have to do anything to the way I have the connections for objects addressed?
No, there's no real correlation between RSLinx Classic OPC Topics and RSLinx Enterprise FactoryTalk Live Data Shortcuts.
What I have done in the past is simply to delete all the RSLinx Classic OPC Topics and delete the RSLinx Classic data server, then re-create RSLinx Enterprise shortcuts with exactly the same names.
All the references in my project followed the name.
Your mileage may vary; I haven't tried this since version 3.20.
Linx Classic is pretty dependable. Is there any other reason you want to do that? If it ain't broken...
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
195
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
161
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,592
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,139
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,424
