LM9030 software
I have it. Send me a PM with your email address and I'll send it to you. Why do you think you need it? Machine Edition software can upload from a PLC even if it was originally programmed with LM90, and it can import a LM90 project folder..
If you plan to use it to communicate with a 90-30 PLC, you will have to run it under a 32-bit operating system. The serial communications driver is not compatible with any 64-bit OS. I run it is a DOS box under 32-bit XP.
Greetings Fellow Techies, What pray tell is OIU_MENU.BAT ? I have GOOGLED THE HECK out of this one, cannot find out what it is. In Logicmaster...
2,048
138
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
125
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
119
