Local time not correct
Do you need two solutions?
Yes as you can see in my program I use a TON timer somewhere, a move block in network 1 and some math functions. This is for the speed measurement with a timer.
I currently set the timer with a signal on field1 and reset it with goal1 or field2 but it also has to reset when I get 2x a signal on the field so let's say the ball passes field1 and bounces next to the goal and crosses field1 again.
Btw CPU is 1214 DC/DC/DC
Plc AE30 V2
Plc AE30 V2
I think I have it, but I don't know where to place it in my program :p
https://ibb.co/gz07f8
My approach on the first one, when the ball bounces out of the goal :
M_TimeRunning Normally Closed and signal on the goal -> Set a random block eg. M_IgnoreTimer
Signal on the field -> reset M_IgnoreTimer
No clue on how to execute the 2nd one, when the ball crosses the sensor 2 times.
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
Is there a way to add a local message display to Studio 5000 View Designer? If its there, I’m not finding it. I have used them in older versions...
411
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
82
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
571
Migrating v8 FT View SE to v13, had to export tags because after v10 the configuration is no longer supported. Imported tags to new Tag Alarm...
513
