Log and retrieve data using PanelView Plus
Acano
Jan 2008
Saltillo
Hi everyone,
I'm building an application using a PanelView Plus 1000, there are some tag values that are adjusted manually by the operator during runtime, I need those values to be stored so in case of a power failure or shut down the data can still available. I know I can log data in a data log file and use an external CF card and also that the data files can be converted later into Excel format, but is there a way to retrive the last logged values of this data directly from the data log file during runtime? Any help would be appreciated.
if the panel view is changing tag values in the PLC, and then reading the new value, any power outage of the panelview would not effect the last tag value stored in the PLC. or are you considering an outage on the PLC as well?
Hi Myles, the data is going to be stored in recipes, the recipe data is the one I need to retrieve in case of a PanelView Outage, thanks
Panelview Plus has a build in recipe function.
You can store all parameters there. Since you are using a 1000 it will look good (the build in app has a tendency to look a bit crappy on smaller displays, fields, etc).
The function is called "Recipe Plus" , there's good tutorial and application example on the aB site.
If you are doing recipe storage in the PLC, then you have to save the values in the PLC so in case of a power outage you can reload the current values on power up. You have to do a bit of code to make it work though.
Thanks bkottaras, Recipe Plus sounds like the solution to my problem.
Thanks for all the previous help...but here's a quick Q. I set up dataloging from FTView SE to dump Data into a MS SQLServer databse (ODBC) Is...
1,908
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
116
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,146
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
103
