Logic 5000 question
justblaze
Supporting Member
Oct 2012
New York
21
Hi everyone,
I haven't dealt with Allen Bradley my self but I have wondered the reason why everyone has a bunch of different versions of Logix 5000 installed. Does the latest version not work with older Compact Logix controllers? Can you not update the firmware on the controller?
I am also curious why RsLinx is a separate utility. Why isn't it built into Logix and Factory Talk?
Thank you in advance.
The later versions have more features that the firmware of the earlier processors would not recognise.
A lot of work places / factories are happy with the firmware version they are running.
They do not wish to upgrade the firmware of their processors.
If you have all the versions installed on your computer you do not have to select a version to start. They all seem to come under the one umbrella sowhen you open a project the correct version will be used.
Regards Alan Case
Maybe.
Yes, you can.
RSLinx is used by many other products besides RSLogix. Making it a separate tool means you only have to setup comms once and all those programs can use it. That way you don't have to set up the same comm settings in each program.
OG
we have a service department and a couple of our customers have Control Logic. With the upgrades how do we keep up with what everyone has at the...
6,096
Good day everyone. if you have a logic for 3 pumps (lead/lag/off), would you please email it to me? I really appreciate it!
228
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,261
Is there any way to install multiple versions of studio 5000 Logic Designer or do I have to install them all individually? Also, I am assuming...
2,477
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,218
