Logic Design Free Software
Mmm, not sure that I like the representation of the hold in circuit.
My favourite in this direction was the Cyrano S/W from Opto 22, but that was 10 years ago, I don't know what their current ofering is like. On the other hand, that cost money, if this is free, it could be interesting to play around with. I assume, however, that this is purely simulation S/W and you can't actually drive anything with it.
Pretty good.
Ukrainian
This is pretty good. I think students will be able to understand their work better with simulation softwares like these.
Nice One! (y)
regards
Sherine T.
Boolean Algebra
GregPLC said:
Does it generate a truth table for you? Or help you simplify logic?
Fundamental of PLC’s programming is Boolean Algebra (see another picture I posted). So, if you build your circuit using Boolean algebra (which is great way to make circuit maximum simple!), you always can test the control you design in logic gates means. So, everybody can practice PLC programming, using this software. Not only programming, but also simulating a circuits.
GregPLC said:
What a way to over complicate a holding circuit ;)
Sometimes people use NO contacts for Stop button when programming holding circuit, so I showed this way. Personaly I like NC better for safety reason. Sorry, if I hurt your feeling.
I've to design logic for pumps in the pumping station. there are 7 pumps in the pumping station in which maximum 5 pumps would be running at...
2,086
Hi Guys, Please Pardon me if this sound odd. I'm to provide PLC functional Design Specification and PLC Logic Desig to a Client. I need to be...
10,059
A temperature control system consists of 4 thermostats*- digital switches. The system operates three heating units- ~digital ori/off outputs. The...
37
7,597
Hello, I am going over some old code from days gone by. I would like the expert to confirm my findings to see if I got it correct. 1. B64:22/3...
408
Hello, I´m having a problem trying to program in Ladder. An output should be trigged by two possible contacts. Take a look on the printscreen...
165
