Login Failed .... Insufficient Acces Rights
samr
Jun 2013
Rochester, NY
User log in (with built in Login button) worked and then for no apparent reason stopped working with "Login Failed .... Insufficient Acces Rights" message. Deleted and recreated groups and users, same names, different names, with and without passwords - no help.
Anybody had this? Resolved?
FTView Studio 6.10
What type of security are you using? With the newer FT versions, if the project is compiled on another computer, login info can be lost as it's contained on the PC that ran the project originally.
What I've been doing for PV+ projects that don't use Windows/network security is to use ME Runtime 3.2 type security and migrate it. This info can then be transferred over.
If you have the option of using network security I would do that then let login and password issues be IT's problem.
I had to install a Historian v6.0 IFIX collector on a 32-bit machine, because the v7.0 collector kept failing on install, despite the manuals...
1,776
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
71
I'm attempting to get a very old system running again that uses allenbradley plc / realview32 i have full access to the windows 2000 installation...
120
  • Locked
  • Sticky
Hi folks, If you're having any login issues kindly send an email to [email protected] or use the 'contact us' link on the bottom of every page to get...
1,128
I am working at a remote site that has a FTView SE system that has been running for years...V9. About an hour ago the operators called me over...
682
