Logix 1768-L45 daylight savings time
sparky mark
Jul 2008
Lititz, PA
Using GSV WallClockTime and LocalDateTime,
when I check the box "adjust for Daylight Savings" it advances the time by one hour. What is the purpose of this box? Can the PLC automatically "spring ahead" by one hour in the Spring, and "fall back" in the Fall at the proper day and time, or must I do some more programming?
Also can I get the Panelview to do the same with Daylight Savings time or to follow the PLC CPU time?
Thanks in advance for your help.
It won't do it automatically unless you tell it to.
Take a look at the samples that are installed with your RSL5000 installation, on Windows 7 they are in C:\Users\Public\Documents\Studio 5000\Samples\ENU\vxx\Rockwell Automation\PlantPAx. All sample program files have a well documented AOI named T_DST that you can use to automatically change the time in spring and fall.
OK. I now have the Daylight Savings Time (DST) AOI. "which will automatically check the box to switch to DST or uncheck the box to switch to standard time"
The AOI is T_DST.
Thanks for your help.
I have a Studio 5000 V30 installation which not have the PlantPAx sample folder referenced above. I could not find a sample project with T_DST after loading several of the ones in the ...V30\Rockwell Automation\ folder, including the Add-on-instruction-samples.
The Sample Code library at <http://www.rockwellautomation.com/global/sample-code/overview.page> does have this add-on. It is downloaded as an L5K which can then be imported into an open project.
This is taken from a previous thread: "With the 1768-L43/45 processors, there is another buss where communications cards can be added to the left...
2,400
Good day all. I'm trying to create a new project with a 1668-L43 CompactLogix controller. When I try to create new, That controller is not in the...
1,900
Absolute newby here. Also new to PLC. But I am a seasoned Electronics and Computer Tech. Helping to get my buddy's machine back up and running...
2,153
I have a question concerning network connectivity to a Compact Logix 5343 1768-L43 processor. Some background information: 1) The 1768 PLC...
1,659
Hello all, first time poster, long time reader. I was wondering if anyone has any experience in integrating a L43 with an 1768-ENBT to a Linux...
1,732
