KNeland
In my very limited experience with control loop tuning, I found the use of derivative to be a hindrance, and dialed in quarter decay with Proportional gain and Integral gain only. This was tuning a very simple level/flow loop.
Currently I am trying to tune 2 PID functions controlling 2 different pumps(motors) that are in series along different points in a flowing process. The first pump PID is based on P.S.I setpoint, with the process variable measured at the front of the second pump, which has a setpoint based on an entered flow rate(G.P.M), which is measured by a Coriolis meter further down the line. In this case I am dealing with previously set up programming parameters, and the guy before me used some derivative on the metering (second) pump.....The process really oscillates up and down, and I was hoping to get some insight in understandable terms, of why to add derivative. Oh...and the proportional gain in that case is low (.01) and integral (.1) with the derivative at .05
Any advice?
thanks
Any advice?
thanks
