Logix 5000 install problem
George- THANKS!!! I hope to reply in bits to this post with clear questions. Before I do,
I'm attaching several images to show the failed results with the newer versions- 10 thru 19 I have on one laptop. I can't recall now which version it defaulted to when I attempted the upload.
Today I followed some of your directions and was able to install the v.8.52 (the 8.20 is a reference to the Firmware- see the images) BUT, I ignored the comment regarding LINX. I use 2.52 on that laptop. I actually went online, started uploading from the PLC it got to about 3 progress bar segments then said can't do it. I'll try and upload those screenshots as well. I worked late, so if I don't finish tonight I hope to do so tomorrow.
I wanted to add: The SECRET to installing the version 8.52 is as mentioned: install just the program- uncheck the other boxes and install them later... that is the problem and why it stops at 47% on the install... thanks again George!(y)
George- Thanks- It worked...
George!!! IT WORKED!!! THANK YOU!!!
I used an old laptop with:
XP PRO SP2
RSL5K V8.52
RSLINX V2.42
REAL WORLD SERIAL PORT
I GOT IT ALL!!! By the way, I work with OEM's if they are still alive and not bankrupt. I lot of what I do is because of dead and bankrupt OEM's and the occasional dead beat OEM.
In this case the OEM emailed me the backup code but his copy is for a newer version of CPU and RSL5K, so now I can provide him with a copy of this backup in case he needs it.
"failed to install studio 5000 logix emulate in slot" for Studio 5000 Logix Emulate Any reason for this?
4,086
Can anyone guide me how to install eds hardware tool inside rslogix 5000. Trying to install eds files to add a module but not able to get the...
10,827
I'm working on a retrofit job, it is using a Control Logix L55, Ver 13, with Devicenet IO and Ultra 3K drives on Devicenet. Now I need to add in...
8,459
Trying to install v30.01 of Logix Emulate on my Win7 x64 VM. I get a message saying: "Unable to upgrade RSLogix Emulate 5000 20.01.00 (CPR 9 SR...
5,759
I would like to install version 15 of rslogix 5000 to communicate with a contrologix controller running version 15 firmware. I am unable to...
11,800
