Install Rslogix 5000 with Studio 5000 DVD?
LowRange
Jun 2016
Omaha
52
I would like to install version 15 of rslogix 5000 to communicate with a contrologix controller running version 15 firmware. I am unable to communicate with the controller due to firmware version incompatibility. Flashing the controller/cards is not an option because I do not have project file and wish to upload it from the controller.
I have rslogix 5000 version 17 and studio 5000 version 21 installed on my laptop. I have a Studio 5000 DVD but I see no option to install an older version of 5000.
How do I go about resolving this issue?
I download straight from Rockwell. As long as you have cd key/serial you should be ok.
http://www.rockwellautomation.com/global/support/downloads.page
Just install the DVD version, it will only load the nessesary files for version 15.
After you did this, and reboot your computer, you will see the version 15 added.
In my experience, you may have to uninstall all later versions of the RSLogix5000 to install an earlier version, the reinstall V15 to 17 or even later.
The activation key stays where it is, so do not worry about that.
I will second Helliana's comment - Install the latest version first, then install the older version(s) in reverse order. Release 15 should install without any problem.
I was able to connect to the controller and grab the project file after downloading version 15 from rockwell. I had to uninstall version 17 1st to get version 15 to install and run.
Thanks guys
Can anyone guide me how to install eds hardware tool inside rslogix 5000. Trying to install eds files to add a module but not able to get the...
10,827
I'm working on a retrofit job, it is using a Control Logix L55, Ver 13, with Devicenet IO and Ultra 3K drives on Devicenet. Now I need to add in...
8,456
Hi all, My PC is win7 pro sp1 64 bit. Wvhen I installed rslogix 5000 V20, it told me that it was not supported on current operating system, please...
4,405
hi all, i saw some of the machine vendors able to open Rslogix 5000 on Win 7, anyone can teach me how to do this?
4,367
Hi Guys I have a issue here, it's a new remote chassis for the plant, and it is comunicating with the CPU via controlnet, and I don't have the...
3,788
