Install EDS file in RSLogix 5000 Ver 13
chavak
Jul 2002
750
I'm working on a retrofit job, it is using a Control Logix L55, Ver 13, with Devicenet IO and Ultra 3K drives on Devicenet.
Now I need to add in a Zumbach measurement sensor on Ethernet IP, and received the EDS file from the vendor. Unfortunately I don't see an option under "Tools" menu to add an "EDS Hardware Installation Tool" option unlike the newer version. Although I installed the EDS file in Ver 27, it doesn't show up in Ver 13.
Is there any workaround for this situation.
Thank You
Best Regards
You will find the EDS Hardware Installation Tool under Start/All Programs/Rockwell Software/RSLinx/Tools.
Tried that in RS Linx tools, but it doesn't bring the option to add in the added device in the Ethernet tree in Ver 13 to Ver 19, but appeared in Ver 20. :unsure:
ControlLogix isn't a "PLC family" in the old sense of the word. If it were, it would have long since been replaced with a newer platform. Every major Revision of ControlLogix is a new and different platform -- only the name remains the same.
You can't add EDS-AOP to V13
You need to ask vendor how to setup a generic Ethernet/IP module in V13.
These are device specific and only device vendor has this info if they are willing to disclose it.
Thanks for the info, I've already wrote to them. Awaiting the reply now.
I guess it is going to be more tough.
Thank You
Best Regards
Hello PLCS.Net! I have the EDS Hardware Installation Tool installed on my PC. When I try to install a file, It says it's successful, the...
2,036
Is there a way for me to manually install eds files on a server which I don't have admin rights? Using the installation wizards, the install files...
5,931
Can anyone guide me how to install eds hardware tool inside rslogix 5000. Trying to install eds files to add a module but not able to get the...
10,827
Not sure when this started or what triggered it, but I went to install RSLinx enterprise on a XP VM, which resides on my ESXi server. If I type...
1,486
RSLogix5000, Version 17 I am trying to install an EDS file, but I can't find a means to do it. In Studio, I can use Tools>EDS Hardware...
2,388
