Logix 5000 programming of a 1794-OF4I (repeat thread)
mswiggins
Aug 2006
Dothan, AL
I am using a Controllogix processor with a DHRIO card to talk to a 1794 ASB. The ASB rack has 4 analog input cards. I have them programmed the MSG for the analog inputs and they are working correctly.
The problem is with the 1794-OF4I MSG instructions.
How long is the read instruction?
How long is the write instruction?
Do I need to have any additional information in the write instruction?
I can not find programming examples for RSLogix 5000.
Hello all, I was trying to do some online programming on a AB control logix PLC v20. I added a new function block routine and added in an SCL...
1,989
hi, i know how to write program in rslogix 500. in youtube video of rslogix 5000 programming i saw that they are just writing character tags (like...
2,026
I have two PB's I want to use with my test bench for fault/fault reset testing (if possible). I can get it to fault but I am not sure how to code...
4,930
Hello I have been programming in RsLogix 5,500,5000 for about 3 years in an electrical and instrument tech position. I am working on a project...
4,180
I am taking my first attempt at modifying a program on our little bottling machine. We need to automate a sequence to purge the tank on the...
4,828
