Logix 5K Data Archiving
joecool2112
Oct 2016
Waukesha, Wisconsin
Good afternoon,
I am relatively new to logix programming and am looking for a simple or relatively simple way of storing a floating point value for future use each time a specific trigger happens. as an example, lets say I fill a 55 gallon drum with Mayo and my scale input to the plc reads 550.7 pounds. the operator then hits tare and the weight would move to a database and the process would start over. What is the best way to store these weights along with time/date.
thanks much!
Joe
Joe
A FIFO Load would do that, just remember to do an unload each time or the file will fill up and stop excepting new loads
you could also do a file shift or just shift the file index each time you want to store data.
Multiple ways to do that.
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
124
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
518
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
135
When adding an IFM AL1322 IO-Link Master Module to a 1756-EN2T Ethernet Card on a 1756-L82E Controller, The Input and Output data file does not...
108
