Logix Designer Studio 5000 Tabs order
krakenfan69
Nov 2011
Alberta
229
This is s stupid thing but it drives me crazy. 5000 seems to open new lad windows to the far left every time. I tend to like to have my Tags folder and then Cross Ref windows on the left. Every new search messes this up and I find myself searching for lad file tabs I just had open. Is there a setting to make the new windows open on the right? I am aware of the drop down on the far right, just doesn't feel natural to me.
Thanks,
****** Fan #69
its rockwell they think different...
everyone: opens tab to the right
Rockwell: We're gonna mess with our customers.... LETS GO LEFT!
I mean I kinda see the point.. open the latest thing at the easiest place to get to left side. But its hardly a challenge for anyone to grab the slider and go to the right to get to it after you change away from it.
It is not nearly so simple.
Let us do some basic testing. I'm using v32 since that's what I happened to open (and OP is presumably using a fairly new version, since versions prior to the interface update wouldn't have tags, xref, and ladder in the same set of tabs).
I open the controller tags and a cross-reference, then a routine... each one is added to the right, exactly as one might expect. I then open a few more routines... again, each one pops up to the right.
It's once the space for tabs to appear is full that things get interesting. At this point, when I open a new routine, it appears to the left, as OP complained.
But wait! If I then open another new routine, it appears to the left... but the previous one vanishes. There's still only one tab to the left of the tags. What happened to the previous one?
Well, let's start closing routines and see where it shows up. I close the routine to the right of the xref tab, then repeat until I can see the routine in question come into view on the right. And one more closed routine later, the most-recently-opened routine, which had been sitting to the left of the tags, vanishes from there and appears on the far right. So these routines were in fact on the right, as one would expect from newly opened stuff.
At this point there's enough information to figure out some of what's actually happening.
The basic rule is not 'new routines open on the left'. It's something more like 'If there's enough tabs open that the current tab isn't visible, show it as the left-most tab regardless of its actual position,' and, since a newly opened routine becomes the current tab when you open it, as soon as you have enough stuff open it will always show up on the left side even though its actual position is far right past where you can see.
I can get multiple tabs to appear to the left of my actual left-most tab (the tags) by swapping between multiple tabs that are too far right to appear, but every time I open a new routine it consistently updates to have only the new, now-current tab showing on the left.
I suspect this is Rockwell's 'fix' for the fact that, in the new interface, you can no longer scroll right & left along your open routines. They needed a new way to show the selected tab if it isn't among the first [however many fit on your screen] opened, and this is it.
I'll be honest, I'm not particularly a fan of this behaviour. But trivializing it as just opening to the left isn't all that accurate.
Yes, it is definitely a spacing issue when there are too many tabs to display. I tested this by stretching the Controller Organizer to the right to reduce the available space for my logic. Then I opened one routine after another and they all opened to the right as expected.
Once that space was full, opening a new sub did indeed display it on the left. But, if I stretched the Controller Organizer back to the left and allowed more space for the logic, then the new sub showed it's correct position on the far right.
Microsoft addresses this in Windows by stacking the same icon along the Start toolbar. If you have multiple instances of Chrome open, you only have one icon. Hover on that and you see the instances. Perhaps, Rockwell looked at or needs to look at that method.
OG
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
135
For some reason, when I do a search (Find in Routines, Text Only) in Logix Designer (v30, v32, or v33), I can press F4 and it will step through...
811
After installing Studio 5000 Logix Designer 33.01.01 , we got some errors. See attached and below. Is it serious? Install failed (1)...
2,092
Hi Folks, I am trying to trend in Logix Designer an element of an INT[223] input data array. For some reason, the "add" button is greyed out. I...
2,195
I hardly ever use Studio 5000 Logix Designer and when I tried to open a project today it just hung at the splash screen. Has anyone experienced...
2,354
