Logix GSV instruction with PF 753 module
Gabe1
Nov 2015
Alberta
Hello all,
Looking for a bit of help with a some programming I'm working on. I'm probably missing something simple. I've got a routine setup for a set of transfer chains that I copied from another transfer. I went through the "new" routine and changed the necessary tags except for two GSV instructions setup as below. In the drop down when selecting the module, I was able to select all other PLC modules (VFD's) setup in the controller other than the one I wanted. I would try to select the new VFD as the module but there would be no change. The module (VFD) in question was just added to the project (the motor was formerly operated from a starter.)
GSV
Class Name: Module
Instance Name: VFD_1 (PLC module visible in the organizer)
Attribute Name: Fault Code
Dest: VFD_2.FltCd ("VFD" user defined data type)
Hello everyone, I am having an issue with random I/O faults on a ControlNet network. In the logic, there is a GSV instruction with LedStatus as...
5,362
All I am studying a PLC program from another facility. It uses an SSV instruction and a GSV. Data in SSV, GSV as follows...
7,410
Hello all, I've read a number of times on the forum that excessive use of the GSV function is to be avoided. Does anyone have any further info on...
2,099
Hello everyone, I am new on here so please excuse my ignorance. I am doing a program conversion from RSLogix 500 to RSLogix 5000. I received an...
17
7,130
Hi Guys, I am trying to get the PLC wall clock to trigger a reset. I have gone through various posts on PLCtalk website and other website did...
3,439
