Logix5000 Max Scan Time with GSV
As Jeremy pointed out earlier, the Rate parameter is the time from the start of one scan of the task until the start of the next scan. So it is how often the task is scanned. Since you are using a periodic task (now) that rate will be fixed and unchanging. It has absolutely nothing to do with the actual scan time of the logic.
OG
It does in a sense. I only have one task (Main Task). With RATE, I (as you said) "pickup time from the start of one scan of the task until the start of the next scan". So should my task time ever overshoot it, that will be equivalent to the too high scan time.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
124
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
I'm a Siemens person, and this is one of my first AB programs. The customer wants everything programmed in Ladder. I have a lot of data (3...
226
Good day everyone. if you have a logic for 3 pumps (lead/lag/off), would you please email it to me? I really appreciate it!
220
Maybe this is just not possible, or maybe I am doing something wrong. Background; I have a data array of over 1500 products. For sorting I...
765
